2000 caravan van will not start code PO340
Old Feb 16, 2010 | 12:11 PM
ldg_1's Avatar
ldg_1
Default 2000 caravan van will not start code PO340
2000 dodge caravan 3.0l
van stopped I have no spark at all van will not start have code po340 I have replaced the distributor with a know good one and checked the wiring coming from the distributor to the pcm, ground is good, has the 8 volts coming from the pcm and the sensor wire from the distributor to the pcm has conitinuity
what could be my problem I checked the asd relay and the fuel pump relay all check ok anything other than what I listed could be causing the problem ?
ldg_1
Old Feb 16, 2010 | 05:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You could have many problems, crank sensor, open wires at or going to the sensor, broken timing belt or crack flex plate.
Old Feb 16, 2010 | 09:05 PM
ez1913's Avatar
ez1913
PO340 = No camshaft sensor detected during cranking.
The cam sensor sends cylinder identification to the PCM to sync ignition with the fuel system.
The Cam sensor is located at the base of the dist on the 3.0.
The cam sensor is $34.99 at autozone.com.
I'd start there.
EZ1
