97 Grand Caravan 3.8 Timing question
Old Feb 23, 2010 | 09:06 AM
jenson611's Avatar
jenson611
Default 97 Grand Caravan 3.8 Timing question
ok so i have a 97 Grand Caravan LE with the 3.8 would not start for the life of me bunch of new parts then i decide to check the timing chain as the guy i got it from said he had to do majior tranny/transaxel work because it shot a gear well i pull the timing cover off and low and behold the timing is jacked up so when i go to replace it with the crankshaft at tdc on cyc 1 do i just need to mach up the marks or will i need to set the cam aswell? and if so how would i go about that?
Thank you
Old Feb 23, 2010 | 10:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
If you want a picture of the timing chain set up i can send you one by email. so just send me an email address and i'll send the picture.
Old Mar 9, 2010 | 09:23 AM
jenson611's Avatar
jenson611
I guess some times things are as easy as the seem
