Compression ring problems
Mar 17, 2010 | 03:26 PM
I have a 2002 Caravan, doing an engine rebuild. The Specs for the 3.8L thicknesses (rings) in mm are 1.5, 1.5, and 3 (top to bottom)
However the compression rings will not fit my pistons (top is supposed to be thinner thinner than 1.5mm, it appears...).
How do I resolve this? they only sell 1 size ring kit for my Caravan... and its incorrect.
It IS a 3.8L, Verified. Only thing wrong is the thickness...
Mar 17, 2010 | 06:55 PM
Did you clean out the ring grooves? Did the engine rebuild kit include your year or did you assume an earlier or later 3.8 kit would work?
Mar 17, 2010 | 09:41 PM
May sure you have the right parts. The 3.3 and 3.8 look the same, but the bore on the 3.8 is smaller.
Mar 17, 2010 | 11:44 PM
You mean the 3.8 bore is bigger right? The 3.8 is basically a bored and stroked 3.3.
Mar 17, 2010 | 11:59 PM
You are right! Bad master tech............... Bore Diameter on the 3.3 is 3.661-3.6617 and 3.8 is 3.7792-3.780 in.
Mar 18, 2010 | 12:10 AM
I'm going to start calling you "Master Typo".
Mar 18, 2010 | 02:39 PM
its a 2002 3.8L, only one kit covers this year, Vehicle, and Engine, and the compression rings are too thick, not too big around...
Mar 18, 2010 | 02:49 PM
those specs are for a 3.3L, the top ring width for a 3.8L is 1.175 - 1.190 mm
