'98 caravan transmission problems
Old Apr 18, 2010 | 06:03 PM
mark a's Avatar
mark a
Default '98 caravan transmission problems
Hello folks,
I'm glad to find this forum here and hope you can help.
My '98 Caravan (3L, 230k mi.) has had problems upshifting and has a rough 2-1 downshift shift since the weather has gotten warmer.
The first time I had a problem, I found the fluid level low. After adding, it immediately shifted better.
Now the problem seems to be coming back, and is worse especially after stop and go driving on a hot day.
Thanks in advance for your help.
Old Apr 18, 2010 | 06:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You need to ck for transmission codes, and there maybe a transmission flash update for the problem you are having.
Old May 15, 2010 | 12:42 PM
mark a's Avatar
mark a
Originally Posted by master tech
Welcome to DF
Thanks for the response.
After driving the car for a while and having the problem occur seemingly intermittently, I can make the problem occur by turning on the A/C.
Any further advice?
Old May 16, 2010 | 07:39 PM
mark a's Avatar
mark a
bump xxxxxxx
Old May 16, 2010 | 11:43 PM
master tech
The A/C circuit should not cause a problem with the transmission. How ever the a/c pressure switch is on the same curcuit as the TPS and MAP/BARO sensor. You may need to have a co-pilot hooked up and record the shifting problems you are having.
Old May 17, 2010 | 04:49 PM
mark a's Avatar
mark a
Thank you for the thoughtful reply.
I thought it was weird to, but worth mentioning. Do you think my problem may be heat related since that's when I'm most likely to run the a/c?
Old May 21, 2010 | 04:01 PM
mark a's Avatar
mark a
bump .......
Old May 21, 2010 | 11:03 PM
master tech
I don't think its the a/c. you could have a problem the u/d acuumulator spring or a valve sticking in the valve body.
