2000 caravan 3.3 stalling
OK so I have a 2000 grand caravan 3.3.. I have had it for three months...I got the oil changed bout two weeks ago and next day the engine light came on/ Next morning i go to start it and it cranks but wont start..unless i feather the pedal.. So i started by changing plugs ( they were really bad) still dies ...So i changed the fuel filter....still dies and has trouble starting... So I change the fuel pump unit.. Runs fine for the day .. Then this morning starts fine dies while driving on the way to store .. then has trouble starting agn. I am at my wits end...
We have a 3.8 and had similar issues with the van stalling. Similarly, we had to feather the throttle to get it running at times. We had replaced plugs, wires and fuel filter as well. We were able to get it running right by relieving the fuel pressure at the relief valve by the intake manifold.
Finally did some searching and decided to start throwing parts at it. Bought an Air Intake Control (AIC) valve for about $90. We haven't had the problem since (knock on wood). It has been running fine for over 6 months.
My next attempt was going to be having the induction system cleaned. From what I read, it sounds like doing this could also clean and correct problems with the AIC valve. However, I think it costs more to do this.
