Back up lights not working
Old Jul 14, 2010 | 03:46 PM
Tizzy1's Avatar
Tizzy1
Internet
Old Jul 14, 2010 | 04:19 PM
sapporo's Avatar
sapporo
where? what's with the evasiveness?
Old Jul 14, 2010 | 04:39 PM
Straycat67's Avatar
Straycat67
Ok so after taking off the transmission pressure switch by mistake I examined the range sensor. I am a little unclear. so what do I use to check for voltage? also it looked like it was "wet" is this contact paste of some sort? Do i need to find my volt meter?
Old Jul 14, 2010 | 04:45 PM
Straycat67's Avatar
Straycat67
Ok my last reply didnt work. I am able to get to the range sensor. What am I doing with it? I see a 3 in the diagram. Am I checking pin # 3?
Old Jul 14, 2010 | 05:14 PM
Tizzy1's Avatar
Tizzy1
You should have power at pin 1 of the 10 pin connector. If you jump pin 1 to pin 6 the lamps should illuminate. If so, the problem is in the switch.
Old Jul 14, 2010 | 10:48 PM
Straycat67's Avatar
Straycat67
thanks tizzy. keep up the good etch e sketch work!!
Old Jul 14, 2010 | 11:08 PM
Tizzy1's Avatar
Tizzy1
I'm an etch e sketch pro.
Old Jul 15, 2010 | 08:47 AM
sapporo's Avatar
sapporo
come on, I thought the purpose of the board is to help each other. I'm asking a quality question and would like to know where you are getting these service articles and pictures you paste in.
Old Jul 15, 2010 | 03:17 PM
Straycat67's Avatar
Straycat67
I tried to jump from 1 to 6. with the ignition on. i used a twist tie to jump. no lights!!!
Old Jul 15, 2010 | 03:20 PM
sapporo's Avatar
sapporo
you verified you had power at pin 1?
does R highlight on the PRND3L dash indicator?
