Back up lights not working
Old Jul 15, 2010 | 03:22 PM
  #21
Straycat67's Avatar
Straycat67
no. how do i do that?. the pnr23 is illuminated. not separate square around the P
Old Jul 15, 2010 | 03:23 PM
  #22
Straycat67's Avatar
Straycat67
i have power for sure. but i dont think 6 is the reverse lite position
Old Jul 15, 2010 | 03:24 PM
  #23
Straycat67's Avatar
Straycat67
process of elimination!!!
Old Jul 15, 2010 | 03:37 PM
  #24
sapporo's Avatar
sapporo
what is prn23?
We are having problems communicating. I want to you get a camera, sit in the driver seat, start the engine, put your foot on the brake, put the transmission in reverse, take a picture of the PRND3L shift position indicator. Post this picture then we will all be on the same page.
Old Jul 15, 2010 | 03:44 PM
  #25
Straycat67's Avatar
Straycat67
ok. so I guess I have no power in the number 1 pin. I used the stripped twist tie to jump the pins and nothing. i did this with the ignition on and off. ??? LOL sorry for that. I did spell vacuum right tho! When turn the car on and it is running the individual PRND3L illuminated and the reverse is highlighted. When the van is not running and i tried to jump the 1 and 6 pin position nothing happens. so..... I am wondering if i am doing this diagnostic correctly.
i pulled the socket off. i inserted the small gauge wire from the twist tie into the female pin locations 1 and 6 with the ignition off and on. nothing hightlighted on the PRND3L or illuminated for that matter. I have to go to school and I will try this again tomorrow!
Old Jul 15, 2010 | 04:27 PM
  #26
sapporo's Avatar
sapporo
are you able to read and comprehend the wiring diagram Tizzy put on?
pin1 comes from a fuse that is HOT when the IGN is on!.
oh and are you checking at the correct connector?
Old Jul 15, 2010 | 04:37 PM
  #27
Straycat67's Avatar
Straycat67
Is using a small piece of metal wire sufficient for jumping the pins?
Old Jul 15, 2010 | 04:39 PM
  #28
sapporo's Avatar
sapporo
sure but did you verify you have 12v @ pin 1 W/ the key ON in the RUN position?
Old Jul 15, 2010 | 10:28 PM
  #29
Straycat67's Avatar
Straycat67
I hate to admit it.... but I think I pulled the speed sensor and not the range sensor. I will give it another go in the AM
Old Jul 15, 2010 | 10:35 PM
  #30
sapporo's Avatar
sapporo
speed sensor has 2 pins and 2 wires. IDK how you could get mixed up between 2 and 10. :?
