'99 Caravan with smoking brakes
Old Jul 23, 2010 | 04:23 PM
DaytonBiggs's Avatar
DaytonBiggs
Default '99 Caravan with smoking brakes
Hope someone on here knows what I should do. Got this van from my parents and the front right brake caliper was siezed, just put on a new caliper and pads then bled the brakes and it is still smoking. Only worse now. I have done brake jobs before and never run into this problem. Any help would be awesome.
Old Jul 23, 2010 | 04:31 PM
DaytonBiggs
Oh ya, its the 3.0L
Old Jul 23, 2010 | 09:17 PM
mfahey's Avatar
mfahey
Bad hose that's collapsed internally?
Old Jul 23, 2010 | 10:31 PM
sapporo's Avatar
sapporo
yep bad hose or pinched steel line but hose is way more suspect
Old Jul 23, 2010 | 11:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
How are the other wheels? Could be a hose or master cylinder. By any chance did you bleed all wheels or just the one wheel?
Old Jul 25, 2010 | 08:36 AM
DaytonBiggs
Other wheels are good, and yes I only bled the one wheel.
Old Jul 25, 2010 | 11:37 AM
sapporo's Avatar
sapporo
here's what you do. take off the wheel, have someone start up the van and push HARD on the brakes, have them release the brakes and you immediately open the bleeder screw, if you have pressure release out of the bleeder, then you have a bad brake hose holding pressure.
Old Jan 19, 2011 | 10:41 AM
aku321's Avatar
aku321
I have a '98 Caravan with the same problem. I first looked into the caliper and it was good. I am going to try testing the hose for holding pressure next (when I put it back together today). Could there also be something going on with the ABS? Just trying to think ahead when evrything else checks out.
Old Jan 19, 2011 | 02:43 PM
hemi4spd's Avatar
hemi4spd
no ABS is designed not to affect the NORMAL operation of the brakes (is merely an addon system)
either a collapsed hose, defective seal in caliper, or maybe just the sliders needa cleaning and some grease.
follow the checks posted above and you'll be able to determine whats wrong
