CEL light not working?
Old Aug 8, 2010 | 08:04 PM
bobinkski's Avatar
bobinkski
Default CEL light not working?
I posted earlier about the EGR valve, I had my van fail the emsion test with P0404 code, no CEL ever came on. I fixed the valve with a new one and no more codes. I noticed that the CEL light does not work. I did a test for the instrument panel by holding the "trip" button in for 10 seconds, everything light up other than the CEL light. Now is this repairable? can a new bulb be replace? or something else? Please help me with this. Thanks guys.
Old Aug 8, 2010 | 10:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may want to remove the cluster and ck the bulb.It maybe burnt out.
Old Aug 9, 2010 | 06:25 AM
bobinkski's Avatar
bobinkski
Master Tech, I had at one time removed the cluster to replace the bulbs to light up the panel, is there a way to open up the cluster to get to that CEL bulb. I dont want to break anything, or does is snap off? Thanks for your help.
Old Aug 9, 2010 | 11:00 AM
Tizzy1's Avatar
Tizzy1
What year is your van?
Old Aug 9, 2010 | 12:15 PM
bobinkski's Avatar
bobinkski
Yes that would help 2005 DGV 3.8
Old Aug 9, 2010 | 01:04 PM
Tizzy1's Avatar
Tizzy1
I think the only replaceable bulbs in '05 are the cluster illumination. Not possitive though.
Old Aug 9, 2010 | 01:09 PM
Tizzy1's Avatar
Tizzy1
cluster is pretty easy to remove though, you pop up the little cover right behind the column covers. There are 4 screws in the cluster bezel and remove it. 4 screws for the cluster and lean it forward to disconnect it and out she comes.
Old Aug 9, 2010 | 02:17 PM
bobinkski's Avatar
bobinkski
I have taken it out once to replace those bulbs, but is there anyway to replace the CEL bulb? or anyother bulb inside the cluster?
Old Aug 9, 2010 | 03:26 PM
Tizzy1's Avatar
Tizzy1
Here's what I could find in the manual....
INTERIOR LAMPS
BULB APPLICATION TABLE
LAMP</B>
BULB</B>
ABS LED/ AIRBAG LED/ ALARM SET LED/ BRAKE SYSTEM WARNING LED/ CONSOLE 194/ CRUISE INDICATOR VFD*/ DOME/RAIL LAMPS 578/ DOOR AJAR INDICATOR LED/ DOOR COURTESY LAMP 578/ FRONT DOOR COURTESY 567/ GLOVE BOX 194/ HIGH BEAM INDICATOR LED/ CLUSTER ILLUMINATION PC74/ LIFTGATE 578/ LIFTGATE AJAR LED/ LOW FUEL INDICATOR LED/ LOW WASHER FLUID INDICATOR LED/ /MIL LED/ OIL INDICATOR LED/ OVERHEAD CONSOLE READING PC579/ PRNDL INDICATOR (BASE CLUSTER) LED/ PRNDL INDICATOR VFD/ READING 578/ SEAT BELT INDICATOR LED/ TEMPERATURE INDICATOR LED/ TIRE PRESSURE WARNING LED/ TRAC OFF INDICATOR VFD*/ VISOR VANITY 6501966/ VOLTAGE INDICATOR LED/ * VFD = VACUUM FLUORESCENT DISPLAY
It appears that the MIL lamp is an LED and not replaceable.
