Altenator belt breaking
Old Nov 7, 2010 | 06:07 PM
doodie1's Avatar
doodie1
Default Altenator belt breaking
Hi,I have a 1999 Dodge Caravan,and I know this sounds crazy,but I,ve just bought my 4th belt,and going to get a machanic to put it on.
I"ve had the last belt put on by another machanic,and he also put on a new (I think tension wheel)but not sure,can anyone tell me what could be breaking these belts.
Old Nov 7, 2010 | 10:33 PM
master tech's Avatar
master tech
Site Moderator & Tech
After the new belt has put on, ck the fan belt alignment on all the pulleys. Are they breaking or slipping off.
Old Nov 8, 2010 | 03:45 AM
doodie1's Avatar
doodie1
The belts are ripping,when they do I have to go out and cut of the piece of belt that is hanging off,then it's ok til another piece comes off.
Old Nov 8, 2010 | 09:51 PM
master tech
Make sure you get all of the old piece's. You didn't say if you have a 3.0 or 3.3 engine?
Old Nov 9, 2010 | 03:26 AM
doodie1's Avatar
doodie1
I have a 3.0 engine
Old Nov 9, 2010 | 10:48 AM
master tech
You may want to remove the timing cover and remove any broken pieces of the other belts that have droken on you. Once you have install the new fan belt, have either you or the tech loosen the p/s pump. This will help to align the belt to the other pulleys.
Old Nov 10, 2010 | 09:22 AM
doodie1's Avatar
doodie1
Thank You Master Tech i'll do that and let you know how that comes out.
