Fuel starvation problem
Old Nov 9, 2010 | 10:17 PM
kilogolf's Avatar
kilogolf
Default Fuel starvation problem
I've got a '95 LE with the 3.3 and in the last few months noticed that when the gas tank drops to a little more than 1/4 full, the van starts bucking and loosing power to the point that I have to pull over because I can't maintain speed, yet the van doesn't fully stall out. When this begin's to happen, no amount of throttle seems to make any differance. If I add just a few gallons of gas at that point, it runs fine. In fact it ALWAYS runs fine, good pickup, no hesitation, no problems at all until the fuel drops down the 1/4 full point.
I use only quality gasoline, replaced the fuel filter and use Chevron Techron about once every two months. None of this has fixed the problem. Also, the Check Engine light, or any lights for that matter, come on. Guages all look normal. The trip computer usually shows about 75 miles worth of gas left and the mileage I was getting, about 275 per tank, seems to concur with my odometer reading.
Any idea or ideas as to what the problem might be?
Old Nov 12, 2010 | 11:14 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like an obstruction in the tank or perhaps the hose from the pump itself to the metal tube the comes out of the tank has a leak inside the tank. I would just keep in at 1/2 tank or higher unless you want to drop the tank and inspect the pump assembly.
Old Nov 13, 2010 | 12:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
You may need to remove the fuel tank. The early vans had a problem with the baffle inside the tanks, and also had problems the pick up tube inside the tank too.
Old Nov 15, 2010 | 11:41 PM
Jetmeck2's Avatar
Jetmeck2
Fuel pump. Been there. Same symptoms.
