06 GC SXT - Heater takes over 20 minutes to blow hot air
Old Nov 18, 2010 | 10:28 AM
A-Dog's Avatar
A-Dog
Default 06 GC SXT - Heater takes over 20 minutes to blow hot air
Greetings...
The heater in our 06 SXT takes at least 20 minutes to start blowing hot air, and even then it blows it for a couple mintues than reverts back to cooler air.
Would this just be a radiator-need-flushing thing, or something more?
Thanks!
A
Old Nov 18, 2010 | 04:27 PM
lxman1's Avatar
lxman1
Site Moderator
That almost sounds like the blend door in the ductwork is broken. It controls the hot and cold settings.
Old Nov 21, 2010 | 11:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
I also would think about replacing the thermostat and gasket too. This would less work to do,instead of removing the dash.Which you may end up doing if the blend doors is the problem.
Old Nov 23, 2010 | 01:53 PM
A-Dog's Avatar
A-Dog
Thanks for the replies fellas. I'm taking it in Saturday to get it looked at.
Old Nov 23, 2010 | 03:26 PM
hemi4spd's Avatar
hemi4spd
T stat first and make sure ur full on coolant, then look into tearing apart the dash if problem persists
Old Nov 23, 2010 | 08:23 PM
sapporo's Avatar
sapporo
that's absolutely the BEST idea.
Old Dec 6, 2010 | 11:44 AM
A-Dog's Avatar
A-Dog
Needed new thermostat and water pump as it was leaking coolant all over.
Old Dec 6, 2010 | 07:52 PM
sapporo's Avatar
sapporo
which would explain no heat as no/low coolant wouldn't allow for heat transfer into the interior
Old Dec 6, 2010 | 10:41 PM
hemi4spd's Avatar
hemi4spd
wow aint that sumthin?
Glad its fixed brother!
