electrical issues
Old Nov 26, 2010 | 09:00 PM
dumdum9599's Avatar
dumdum9599
Default electrical issues
hello all i have a 1998 caravan that is driving me crazy as the headlights don't turn off and the windshield wipers don't function at all and the blower motor does not work either, and i have been unable to pinpoint the problem so i was wondering if you all could help point me in the right direction i have ruled out the bcm as the lights remain on even with it disconnected. so any help would be very much appreciated.
Old Nov 26, 2010 | 10:05 PM
master tech's Avatar
master tech
Site Moderator & Tech
Well my first guess for the headlamps, would be the switch itself. Try unpluging it. 2nd You could have a blown fuse,open circuit,bad ground,bad motor assy, or multi-function switch.
Old Nov 26, 2010 | 10:27 PM
sapporo's Avatar
sapporo
I think there are several problems. BCM has control of headlights and wipers. a real scanner would help with pinpointing some of these problems. blower motor would probably require a DVOM to pinpoint that problem.
Old Nov 26, 2010 | 11:33 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
That's a default. They are supposed to stay on.
Old Nov 26, 2010 | 11:52 PM
dumdum9599's Avatar
dumdum9599
ok i have already replaced the wiper switch and the headlamp one as well right now i suspect a short in the wiring but i am having trouble locating it.
Old Nov 27, 2010 | 12:00 AM
TNtech's Avatar
TNtech
When the new body style changed over from 95 to 96 (96-2000) there were a ton of issues with wiper "ghosting". Most of the time (not all) it was a result of the wiper switch. Sometimes there was an issue with wiper wiring but not always. However, your problem sounds like BCM or BUS related issues at first glance.
Old Nov 27, 2010 | 10:18 AM
dumdum9599's Avatar
dumdum9599
what is the bus. and is t here any way to tell where the problem lies
Old Nov 27, 2010 | 05:26 PM
dumdum9599's Avatar
dumdum9599
ok i have an update i belive the problem is around the hvac wiring because when i move the wires in that area around every thing starts working until they are bumped.
