Axle nut size for front hub?
Old Nov 27, 2010 | 10:25 PM
salmonz's Avatar
salmonz
Default Axle nut size for front hub?
Today I tried taking off the from hub nut with a 32mm impact socket and was too small. What is the correct size for the front hub nut for a 2000 Dodge Caravan 3.0L?
Old Nov 27, 2010 | 11:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
The socket size is 1 1/4 inchs. 160 ft pounds is the torque specs.
Old Nov 28, 2010 | 06:35 AM
sapporo's Avatar
sapporo
1 ¼" is 32mm show us a picture of your 32mm socket not fitting the nut because they are all that size from 1984. My factory service manual says 180 ft lbs.
Old Nov 28, 2010 | 10:50 AM
salmonz's Avatar
salmonz
I checked the socket and it says 32mm inscribed into it and doesn't fit the axle nut. Would it be 36mm?
Old Nov 28, 2010 | 12:32 PM
salmonz's Avatar
salmonz
Maybe I'm not asking the right question...
There's a Hub and bearing Nut lock and then there's the Hub and bearing Nut.
What size is the Hub and bearing Nut lock?
Old Nov 28, 2010 | 01:41 PM
master tech
You are asking about the nut that threads on the drive axle? If you have a 36mm socket try it. But the correct size is 1 1/4 inch. I use it every day.
Old Nov 28, 2010 | 01:42 PM
sapporo's Avatar
sapporo
post a pict, then there's no misinterpretations.
after you removed the cotter pin, then did you remove the castle to access the nut?
Old Nov 28, 2010 | 10:32 PM
salmonz's Avatar
salmonz
Boy I'm a dummy..
The castle nut is not fastened. You just take it off by hand to reach the nut. The 32mm socket fits the nut.
Thanks guys! Now I don't need anything bigger than 32mm in my set, for now.
I took someone's advice and bought a good impact 1/2" and 3/8" socket set which I thought would cover all the basis. With having the power impact wrench and the new sockets, life became a whole lot easier.
Old Nov 29, 2010 | 05:48 AM
sapporo's Avatar
sapporo
Originally Posted by salmonz
Boy I'm a dummy..
at least you know your limitations. incredible how something so simple can turn into a panic.
