Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
I will do that first things tomorrow. So, incase it doesn't work. What other things should I consider checking, before stripping down the blower? Just hope the resistor is the issue.
Well, I'm sure surprised. It's not just melted but one of the pin is broken as you can see in the picture. So what is behind panel walls? Since that broke, I will need to replace that.
Originally Posted by Tizzy1
and when you take it apart, don't be supprised when the connector is melted to the resistor and they won't come apart, it happens all the time.
Thanks for the diagram. The 2 screws is not a phillip nor flat head. It looks like riveted it. Now, I'm gonna have to find out how to get it out and probably go to junk yard get for a new used socket/plug.
The rivets do not come out you insert a flathead screw driver under the outboard side, read the removal instructions and reference the picture under the instructions.
