New PCM and Blue Smoke
Old Dec 7, 2010 | 07:33 AM
KimC's Avatar
KimC
Thanks for all the responses.
I'm going to see if I can be a little clearer, I realize I may not have said everything I should.
When vehicle first started acting up and it went into the shop, although the codes it was showing was different each time, the mechanic, based on the two frequent ones, replaced the crank shaft sensor.
Problem didn't correct. After talking with some others and researching, he went all the way in and checked the flex plate. It's fine. In putting the vehicle back together, he checked everything he could possibly imagine - including wiring. Could find nothing.
He admitted he was at a complete loss. That's when he said may be PCM.
That's when we opted to get the new PCM. Installed, and now new problems of blue smoke and strong gas smell. But every check the codes are same: P0335 and P0202.
Hope this helps clear some things up. I really do appreciate all the responses!
Old Dec 7, 2010 | 07:16 PM
KimC's Avatar
KimC
Updates:
Received replacement PCM today. Installed. Blue smoke problems gone. Problem with starting and hard jerks when accelerating still present.
So, based on advice here, reinstalled original PCM. Same problems still present.
Only one code now, however. P0335. Which, from what I understand, is the crankshaft position sensor circuit.
We had the crankshaft sensor replaced when problems first started. Is it the wiring?
Old Dec 7, 2010 | 10:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
So there was no more codes with 2nd PCM. But with the original you have code P0335. I starting to think you have a wiring problem, I would open up the wire harness that is routed around the power steering reservoir.
Old Dec 8, 2010 | 10:07 AM
KimC's Avatar
KimC
2nd PCM replacement had P0335 code, but was acting just as the original PCM did - which is why the original was just put back on. Starting from scratch.
Fortunately we've located a mechanic who formerly worked at a Dodge dealership, as well as his wife drives a Dodge Caravan. Since we're at our wits end with what feels like a runaround, we're going to take it to him.
But, MT, I'm betting you're right on the money. I'll be sure to come back and update as soon as I know.
Thanks so much to everyone.
Old Dec 8, 2010 | 11:27 AM
hemi4spd's Avatar
hemi4spd
kim,
the crank sensor code is relating to the wiring not the sensor.
have your mechanic check the crank sensor plug for voltage and ground, then delve into the harness if you find a fault.
