odd tranny problem
2000 dodge grand caravan sport the other day i was driving the van and i took of from a stop light and loud pop occured ever since then it has been driving very bad at first we thought drive shafts then replaced both of those then we thought motor mounts replaced those aswell the problem seems to ocurr when turning to the left feels like it is in four wheel drive like the older four wheel drives were they would bind when turning. so after all that we stumbeld apon somthing when my step father put his hand on the van and leened a littile bit on it it poped again and then moved about a foot and all whyle in park .what could cause such a problem and could a guy do this at home any help would be nice thank you
At this point you're just guessing and throwing parts at the problem. Read the post below on how a pro would diagnose this noise.
http://www.ricksfreeautorepairadvice...ofessional-way
Disconnect the kick down cable and see if you have the same problem. If the transmission does not pop out of park, the problem is the valve body. The problem is the kick down lever is frozen.
Trending Topics
must have a 2.4 4cyl to have a 3speed in a 2000 van.
A.T., 4 spd, 3.0L
A.T., 3 spd (2.4L)
A.T., 4 spd, 3.3L, from 9/29/98
A.T., 4 spd, 3.3L, thru 9/28/98
A.T., 4 spd, 3.8L, AWD, from 9/29/98
A.T., 4 spd, 3.8L, AWD, thru 9/28/98
A.T., 4 spd, 3.8L, FWD, from 9/29/98
A.T., 4 spd, 3.8L, FWD, thru 9/28/98
A.T., 4 spd, 3.0L
A.T., 3 spd (2.4L)
