Any suggestions??
Old Jan 3, 2011 | 07:09 PM
kayjay's Avatar
kayjay
Default Any suggestions??
I have a 1997 Dodge Caravan. Recently it has started having an issue that when I am going up a hill it starts acting like Im driving a standard. Its as if I was driving in 4th or 5th and need to gear down. If I step on the gas and pick up a little speed it stops and is fine. Any ideas what it could be? Ive had one person suggest it could be the O2 sensor and another said the fuel pump
Old Jan 3, 2011 | 09:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You could be feeling the torque converter in lock up. Did the ck engine lite come on at anytime?
Old Jan 3, 2011 | 11:03 PM
kayjay's Avatar
kayjay
yes the check engine light cam eon and has stayed on
Old Jan 4, 2011 | 12:33 PM
Pete M's Avatar
Pete M
gotta get the codes. you should be able to get most with the key test. off-run-off-run-off-run and then count the blinks of the check engine light. they will come in groups of flashes, and then you'll pair then in to groups of 2 digits. have a pen handy.
Old Jan 4, 2011 | 07:23 PM
kayjay's Avatar
kayjay
the check engine light doesnt blink at all it just stays steady
Old Jan 4, 2011 | 08:12 PM
hemi4spd's Avatar
hemi4spd
have it read at an autozone or similar place for free
Old Jan 5, 2011 | 11:58 AM
Pete M's Avatar
Pete M
x2.
but if you're doing it right, it should blink an "all clear" message. try closing the door if it was open.
