Multi Electrical Problems???
Old Feb 11, 2011 | 02:15 PM
96Caravan's Avatar
96Caravan
Default Multi Electrical Problems???
I have a 96 Dodge Caravan and I seem to have a problem. The turn signals/hazards do not work, as well as the blower motor, the rear wiper, and the rear defrost.... I have checked all the fuses and the related relays... Everything seems good.
I did use a jumper wire to check the Really tall fuse under the dash and with the jumper wire everything would work when jumped. So I spent the $80 and got a new relay but that did nothing.
Anyone have any ideas what could do this?
Old Feb 11, 2011 | 09:27 PM
22DODGE22's Avatar
22DODGE22
A bad fuse, or other electrical problem like broken wires. If I had this problem, the first thing I'd do is get a wiring diagram. After all that's the road map for your car. If you were taking a trip, you'd use some type of map to figure out what route to take.
Old Feb 11, 2011 | 10:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I didn't see anywhere that you used either a DVOM or a 12 volt test light. Like 22dodge22 had said, could be fuse's which you said you checked. Could be an open circuit or a BCM. I would remove the relay for turn signal/ 4way flasher and ck for power and ground. And then the blower motor and the rear wiper the same way. And if you need some diagrams, I may still have some. I would need your email to send the diagrams.
Old Feb 12, 2011 | 01:48 PM
frecod's Avatar
frecod
I need one of these diagrams if you still have one.
Old Feb 12, 2011 | 05:46 PM
BlaineM's Avatar
BlaineM
What is the history of these problems? Did they all fail at the same time?
Old Feb 12, 2011 | 11:42 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
It sure is sounding like something inside the junction block. That's a lot of testing to make sure though. Get the wiring diagrams. Also check your ignition switch wires in the column and see if they are burned.
Old Feb 20, 2011 | 09:43 PM
96Caravan's Avatar
96Caravan
I have checked all fuse's / Relays and have all the wireing diagrams , everything is checking out so far but still no power to any of the above mentioned , I even replaced the fusebox&computer under the dash.I did find out theat the Voltage regulator for the Blower was bad I am really getting blown away by this and the only other thing I can think to do is to tear all the wires apart and check each and everyone of them . starting to get really frustrated with the whole ordeal ! PLEASE HELP
Old Feb 20, 2011 | 09:47 PM
22DODGE22's Avatar
22DODGE22
Did you check any wires under the PDC next to the battery?
Old Feb 20, 2011 | 10:12 PM
Cougar41's Avatar
Cougar41
Hi guys and gals! First post.
This sounds like a key clue to your problem. Can you expand on what the "Really tall fuse" was. You then say you jumpered this "fuse", everything worked, so you replaced a relay. Why a relay after jumpering a fuse? Can you include contact numbers off the wiring diagrams you now have of exactly where you installed the jumper?
Old Feb 20, 2011 | 11:23 PM
master tech
Looks like fuse 15 powers up the relay in the junction block. Do you have any power at the relay in the junction block?
