2001 Caravan speedometer is pegged
Old Feb 27, 2011 | 02:25 PM
RSCHWARTZ's Avatar
RSCHWARTZ
Default 2001 Caravan speedometer is pegged
Our caravans speedometer is pegged all the way over it moves a bit when I start it but justs stays pegged and will not work.
Old Feb 27, 2011 | 03:28 PM
Cougar41's Avatar
Cougar41
Try holding both odometer buttons in then turn the key to on. Keep the buttons pushed until the gauges cycle. After 10 seconds or so the gauges should go back to zero.
Old Mar 1, 2011 | 01:23 PM
RSCHWARTZ's Avatar
RSCHWARTZ
I tried holding down the odometer button but it did not reset I even put in a new battery due to it's age 8 years old the odometer works but the needle is just pegged out.
Old Mar 1, 2011 | 06:16 PM
Cougar41's Avatar
Cougar41
Did anything move during the test?
Old Mar 1, 2011 | 09:00 PM
RSCHWARTZ's Avatar
RSCHWARTZ
Nothing happened when I did the test the only thing I notice is when I turn the key to the off position the needle comes off the peg but when I turn the key to the on position it still pegs out.
Old Mar 1, 2011 | 09:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you have this same problem with the old battery too?
Old Mar 2, 2011 | 01:21 PM
RSCHWARTZ's Avatar
RSCHWARTZ
Yes it did. Would there be any codes concerning this? How much work is involved pulling out the instrument cluster can I reset it if I remove the cluster or should I look at finding one at a bone yard?
Old Mar 2, 2011 | 04:01 PM
master tech
You could have stored codes. It could have either a gauge problem or the circuit board.
Old Mar 3, 2011 | 01:24 PM
RSCHWARTZ's Avatar
RSCHWARTZ
Update!!! Decided to try holding down the odometer button one more time and the dash lit up like a christmas tree went through some sort of a self test and finally reset!! Thankyou all for the help YOU GUYS ROCK!
Old Apr 5, 2011 | 11:55 AM
vladhed's Avatar
vladhed
RSSCHWARTZ,
What exactly did you do? Hold in the odometer button, insert key and switch ON?
My wife just phoned me from the gas station - she was trying to reset the trip with the van off and now the odometer, speedometer and tach dont' work?!?!? The van did start and she was able to drive home no problem. She was suitably worried because we know the PCM has a P0601 internal fault code in it.
