2001 dodge grand caravan stuck in 1st no speedo
Old Mar 18, 2011 | 02:28 PM
rmpjmp3905@live.com's Avatar
rmpjmp3905@live.com
anyone out there have the diagnostic flow chart for p1698 for a 2001 grand caravan 3.3liter?
Old Mar 29, 2011 | 08:11 PM
rmpjmp3905@live.com
the tcm b+ wire between the ipm and the tcm had a break around 20 inches from the 60 pin tcm connector so the tcm was not powering up and therfore not communicating with the pcm i repaired the break tested for 12v at pin 56 yellow with red wire and tcm powered up shifting good and speedometer working thank you master tech for the schematics it was a huge help!!!
Old Mar 29, 2011 | 08:19 PM
Cougar41's Avatar
Cougar41
Great job. Thanks for posting the fix. Any idea what broke the wire?
Old Mar 30, 2011 | 03:10 PM
rmpjmp3905@live.com
we bought the van used about 3 1/2 years ago and it looks like someone was testing for power with a test lite by poking through the wires insulation there was a small puncture hole in the wire and corrosion seeping from the whole and i live in buffalo with the winters we get a small puncture whole combiened with road salt do alot of damage but thats what it looks like
Old Oct 6, 2011 | 04:17 PM
1996grandcaravan's Avatar
1996grandcaravan
I have this exact same problem on my 1996 Grand Caravan. What's the best way to figure out the exact location of the problem without having to use a code reader.
Old Oct 7, 2011 | 11:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I could send you the pdf file and you can using it without a scanner. Or you can send a message the member that fix their problem. I don't know when that member will be back online. But if you need the pdf file, just pm your email address to me and I'll send it.
Old Oct 7, 2011 | 02:19 PM
scotthatten's Avatar
scotthatten
im new to this site. where do i go to ask a question about the idle on an 01 caravan?
Old Oct 7, 2011 | 02:25 PM
scotthatten
i guess all i need to know is if 800rpm is normal idle for a caravan in park
