1997 Dodge Caravan missing?
My caravan seems to be missing, When idling it shakes a bit, You can see the steering wheel vibrating and you can sorta hear it. its not a steady vibration, More like every 5 or 10 seconds. Whats causing this? New wires,plugs,rotor, cap a couple days ago
You didn't have the dist out? Two things to recheck, 1 the dist rotor,is the screw tight on the dist shaft.2 make sure the wires are correct on the dist cap. How was the van running before the tune-up?
Not sure which one is missing, There is a knock when it first runs, then it goes away after it warms up, i was told it was the lifters.
Trending Topics
burnt valve or perhaps failed valvespring?
what weight oil u using? and is it old?
lifters will "tick" knocks are ususally conrods, wristpins, or rockers
did you not determine what was the dead cylinder by reading the old plugs?
