2002 Grand Caravan sport tranny problems
Old May 24, 2011 | 02:52 AM
Saphire101's Avatar
Saphire101
Default 2002 Grand Caravan sport tranny problems
could anyone please help me out by letting me know why reverse just stopped working i didnt hear any strange noises , got out of my driveway went to the store still worked , when i went to another store i put it into reverse and nothing. All of my forward gears are working perfectly and when i put it into reverse i can feel it go into gear but it doesnt lock in to move the vehicle . What could be the problem ????
Old May 24, 2011 | 04:38 PM
hemi4spd's Avatar
hemi4spd
maybe reverse clutch is malfunctioning
I'm assuming this is a 4speed?
u may need to check pressure at the reverse clutch port pressure @ 1500RPM should be 165 -235psi, or have someone do this
Check Engine Light come on yet?
Old May 24, 2011 | 07:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
What size motor do you have, and do you know if you ahve a 3 speed trans or 4 speed?
Old Jun 7, 2011 | 01:02 AM
Saphire101's Avatar
Saphire101
It has the 3.3 engine and is a 4 speed
Old Jun 7, 2011 | 01:03 AM
Saphire101's Avatar
Saphire101
Oh and i have no engine light on
Old Jun 7, 2011 | 12:28 PM
master tech
Are you having any problems with 1st gear at all? Because I'm thinking the low/reverse accumlator seal is leaking fluid pressure or broken hard part inside the transmission. Did you check the fluid level and condition?
Old Jun 8, 2011 | 04:07 PM
Saphire101's Avatar
Saphire101
all of my forward gears are working perfectly gearing up and down automaticly as well as manually from D to 1st and from 1st to D . My fluid level is good and the condition is like new no burnt smell and is clear red . I had the fluid changed about 2 yrs ago and this started about 10 months ago. Like i said before it enguages u can feel it but it doesnt lock in to move the vehicle backwards
