2002 caravan steering column locked and now vibrating
Old May 26, 2011 | 10:04 PM
Madtownjr's Avatar
Madtownjr
Default 2002 caravan steering column locked and now vibrating
Today I got in my van and the steering was locked and I could not turn the key. I jiggled the key for a long time while turning the wheel and that didn't work. While trying to turn the wheel I seemed to lock it even tighter. Determined to get it started I kept pulling the wheel harder while turning the key when finally...success...the key turned and the van started. Problem is when I tried to turn the wheel the steering wheel shook and made a loud vibrating noise. I only had to drive it about 6 blocks so I kept going and it seemed to get better as I drove. But as I slowed to pull into the driveway, it came back as I was turning in. Loud vibrating and shaking. My question is was there something wrong before I unlocked the wheel or did I damage something further by trying to forcefully turn the wheel when I was trying to unlock it? I'm a car repair novice so I'm wondering if there are any ideas on what might be wrong. On a side note, my airbag light has been on for quite a while. Wondering if that could be related to this problem or if that is something different all together. Thanks in advance.
Old May 27, 2011 | 12:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
It would be hard to say, until you remove the steering wheel and upper and lower covers to inspect the problem.
