02 GC Rear AC blows warm
Old Jun 2, 2011 | 12:50 PM
scotter5's Avatar
scotter5
Hi tizzy. are you speaking about the rear expansion valve? if the front vents are cold then the front expansion valve is working,,right?
Old Jun 2, 2011 | 01:30 PM
Tizzy1's Avatar
Tizzy1
Correct. Most of the oil drops to the lower lines taking most of the crap with it. Which is why when a compressor grenades, the rear h-valve is usually the first to plug up.
Old Jun 3, 2011 | 09:25 PM
moereece's Avatar
moereece
Replaced valve evacuated and filled system. Everything is running just right. Thanks to both of you for all of your advise. Much appreciated.
Old Jun 4, 2011 | 12:42 PM
scotter5's Avatar
scotter5
Well I am certainly glad everthing if fine now. You replaced rear expansion valve, but i still don't understand why the line going to the expansion valve was not cold when you touched it prior to going to the expansion valve. Anyone explain that?
Old Jun 4, 2011 | 06:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
As tizzy had said. If the debris travels thru the lines. Ends up the H-valve or expansion valve, then you don't have any flow. Then the A/C system can't compete its cycle from gas to liquid. Then both lines would be warm.
Old Jun 5, 2011 | 02:35 PM
Tizzy1's Avatar
Tizzy1
correct!! No flow, no cold. If the lines get cold, the valve is most likely working.
Old Jun 5, 2011 | 06:04 PM
scotter5's Avatar
scotter5
Thanks for the info. I am learning, just takes time, lots of time, at least for me.
