2000 3.0 caravan won't start
Old Jun 4, 2011 | 05:35 PM
dodgeforce39's Avatar
dodgeforce39
Default 2000 3.0 caravan won't start
Van turns over no start. I replaced fuel pump last year acts like its bad, however I disconnected hose into fuel rails and cranked car and fuel pours out of the hose so doesn't appear to be fuel pump. What and how do check next. How do I check ignition fire? update I tried switching out the autoshutdown relay with the horn relay. Nothing.
Old Jun 4, 2011 | 07:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
You need to ck to see if you have spark at the plugs. Remove a spark plug and using a jumper wire, ground the spark plug to ground and with the wire on the plug. Turn the engine over and see you have spark.
Old Jun 4, 2011 | 07:15 PM
dodgeforce39
I went a ahead and did that before your reply, It had spark present.
Even though gas comes out of the hose could it be pressure issues with the pump?
Old Jun 6, 2011 | 08:18 PM
dodgeforce39
I did all the above then today I crank the car and then disconnected the fuel line to the rail. I then turned the car on to turn on the pump to pressurize the system and no gas came out on about 3 attemps. I then crank it to let it turn over and try to start. Then I got some gas to come out. I reconnected and opened the intake and put a little gas in the chamber and it started for about a second. More than it does on it's own.
Should there be enough pressure in the lines to spew out gas when I first disconnect?
Old Jun 6, 2011 | 11:38 PM
master tech
I would guess you have a fuel problem, You may have fuel flow, but no volume.
Old Jun 12, 2011 | 01:38 AM
dodgeforce39
Fuel Pump fixed it.
