[3rd Gen : 96-00]: Infinity Speaker replacements
Old Jun 23, 2011 | 12:08 PM
paradiddle's Avatar
paradiddle
Question Infinity Speaker replacements
can you just rewire a standard speaker to work with Infinity?
I have replaced various speakers on my 97 GC with OEM Infinity from EBAY. They don't last or they cut in/out etc.
Old Jun 23, 2011 | 02:33 PM
Tizzy1's Avatar
Tizzy1
yes. Infinity speakers are just self amplified. Pin 1 is ground for the amp, pin 2 is the speaker -, pin 3 is the speaker + and pin 4 is 12v for the amp. Just connect a regular speaker and use pins 2 and 3.
Old Jun 24, 2011 | 12:07 PM
paradiddle's Avatar
paradiddle
I can probably test with a spare speaker for output. Without the amp would the output be crappy? I will find out......
Old Jun 24, 2011 | 12:18 PM
Tizzy1's Avatar
Tizzy1
I've done it before and it was better sound. My wife had a Daytona with infinity speakers that crapped out. Put some nice JVC speakers in the back and in the doors and it worked great.
Old Jul 8, 2011 | 08:30 PM
theStever's Avatar
theStever
Default How to find Speakers that fit
I've gone to the crutchfield.com site and found excellent speakers. Got Sony for my Intrepid. You can replace them yourself. I got a new radio through them as well. Good price, excellent advice. If you can't replace the radio yourself, Best Buy does it for about $55.00. Crutchfield will include all the needed wiring by the way.
Old Jul 10, 2011 | 02:11 AM
paradiddle's Avatar
paradiddle
I think the 90's infinity speakers had 4 wire amps and 00's had non amplified 2 wire speaker.
examples of pre - 99 speakers
http://www.allpar.com/stereo/speaker-repair.html
Old Jul 14, 2011 | 12:44 PM
paradiddle's Avatar
paradiddle
Talking found a cheap fix
I cut the 2 wires to the "blown" infinity speaker itself ( blue and white ). and then crimped on insulated female blades. Then I plugged it into the connector on the speaker X and - and it works!!. It's missing a little of the amplified thump but good enough for me. now I have all 6 speakers working plus the 2 little tweeters way in the back.
The 5x7 door speakers seem to be the most troublesome for me, never had a problem with the rear 6x9's. I also had to replace a round dash speaker awhile back.
Old Oct 3, 2011 | 05:54 PM
Chazwel's Avatar
Chazwel
I am replacing all 6 speakers in my 2000 GC. I was wondering what those big black things that were attached to the speakers were, amps, I guess. so I guess to make the replacement speakers work, just cut the plastic connector off the use the blue and white wire to connect to the new speakers. Is this right? Thanks.
I believe I have 4 wires to each speaker.
Can you just wire the new speakers with the amps?
Old Oct 4, 2011 | 10:23 PM
paradiddle's Avatar
paradiddle
yes they are amps. If you are going to do that you should replace the radio with one that has some amps
Old Jan 9, 2012 | 01:53 PM
Chazwel's Avatar
Chazwel
Just to update, there are 6 wires to the rear speakers, 2 for the speakers, 2 for the tweeters near the rear door, and 2 for, I am guessing the original amps.
