stuck in 2nd gear - again
Old Jul 26, 2011 | 05:30 PM
peshewa's Avatar
peshewa
Default stuck in 2nd gear - again
I have a 1996 T&C auto with a 3.3 - it is intermittently stuck in 2nd gear. I replaced the solenoid pack & it still intermittently reverts to limp mode. Anyone have a clue what is wrong with this thing?
Old Jul 26, 2011 | 11:18 PM
derekio's Avatar
derekio
wire came apart in the harness? under engine there's a big yolk(y) of wires, cut the tape and I bet you find a wire apart. put it back together and your problem is fixed.
Had this happen on my van, changed everything until a dealer told me that that wiring yolk was a common cause.
Old Jul 26, 2011 | 11:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
What code are you getting in the transmission module?
Old Jul 27, 2011 | 03:24 PM
peshewa's Avatar
peshewa
There are no codes - as in, zero voltage to the diagnostic terminal. I did take the harness apart under the radiator several months ago, found 6 wires that were burned in 2 & fixed them. The horn & radio are dead circuits, I installed a new radio using the connection to the 12 power outlet yesterday, then this happened. All fuses under the dash & under the hood are good. I took off the kick panels under the column and a 5 minute check showed nothing that looked wrong, but I cant run the A/C because something in the vent smells very dead & rotting. Can the wiring in the dashboard cause the limp mode? I heard it is sorta easy to remove the dashboard - 6 fasteners, but I dont know where they are.
Old Aug 2, 2011 | 07:00 PM
peshewa's Avatar
peshewa
I am pulling a wiring harness for the engine bay from a junk yard this friday & putting it in to see if this helps. Getting around in 2nd gear at 35ish MPH uses a TON of gas!
Old Aug 7, 2011 | 05:48 AM
peshewa's Avatar
peshewa
I put in new input & output speed sensors, no result there. I was unable to find a matching fuse box for mine, but I did find another wiring harness. Now I just need to put that in to see if it will fix this issue.
Old Aug 7, 2011 | 02:31 PM
master tech
Are you getting any voltage to the solenoid pack? And are you getting voltage to the TCM and then goes away?
Old Aug 11, 2011 | 04:24 AM
peshewa's Avatar
peshewa
Problem fixed! All I needed was a trip to the salvage yard for another wiring harness, at least the part from the tranny computer to the solenoid pack & both speed sensors, a good wiring diagram and a bit of a sunburn.
