Dodge Grand Caravan 2004 cruise control does not set
Old Jul 31, 2011 | 08:56 PM
graydodge2004's Avatar
graydodge2004
Default Dodge Grand Caravan 2004 cruise control does not set
Hi,
I am new to this site, and to car fixing; yet I will do my best to learn. Thanks in advance for your help and patience.
This problem is fairly new; When I switch the cruise contorl, the light goes on, but when pressing the set button nothing happens.
Best regards,
Dodge Rider.
Old Jul 31, 2011 | 10:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Did you check the vacuum line going to the servo? If you did, the next step is to check the switches with scanner to see if they are changing values.
Old Aug 1, 2011 | 08:06 PM
mfahey's Avatar
mfahey
Make sure your brake lights aren't on as that will cancel the cruise control.
Old Aug 3, 2011 | 12:02 AM
graydodge2004
Originally Posted by master tech
Welcome to DF
Thank you Master Tech.
I tried to find a picture of the servo on the internet, but I failed. Could you please tell me where can I find the servo?
Thank you.
Old Aug 3, 2011 | 12:04 AM
graydodge2004
Hi mfahey,
why should my brake lights be on? you mean if there is something wrong with them? If that's the case, my break lights are ok.
Thank you.
master tech
Its below the battery tray. near the ABS module. If the brake switch is applyed, but the lights are not on. The speed control will not set.
Old Sep 4, 2011 | 08:42 PM
Hate em but keep buying em's Avatar
Hey mine is not setting either. How "check the switches with scanner"?
Old Sep 4, 2011 | 11:21 PM
master tech
You need a scanner that can read all the modules, Not just the PCM. I use a DRB3 that the shop has.
