2010 Grand Caravan Transmission wouldn't shift
Old Aug 11, 2011 | 01:13 PM
WiRik's Avatar
WiRik
Question 2010 Grand Caravan Transmission wouldn't shift
As I was driving our '10 G. Caravan SE (has 3.3 V6 w/ 4spd. auto.) the other day I noticed the following:
Accelerated up a highway on-ramp and noticed the vehicle revving more than normal, tachometer showed @ 4K rpm, and was travelling about 50 mph at this time. As there was an exit ramp just ahead, I pulled off and proceeded to drive in town at speeds of 25-30mph, noticing that the transmission did not shift. Also, tried the +/- gear selector but it remained in "drive".
After stopping for a moment, with the key turned off, and retarting the engine, I tried the +/- selector and it worked, drove along and everything has been fine since, shifts as usual, at least for now.
Question is, would there be any code stored from the no-shift event, or do I just wait for it to happen again??
Just hate these intermittent problems!
Old Aug 12, 2011 | 12:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
Yor transmission may have gone into limp in. Thats what happens with transmission with autostick. The autostick will not change to either a low gear or a high gear. I would have the transmission checked for any stored codes.
Old Aug 13, 2011 | 12:05 AM
smokin' dodge's Avatar
smokin' dodge
I had this happen on an older (1999) Dodge Intrepid. Only happened 5X in 4 years. No solution except restart.....
SD
Old Aug 13, 2011 | 12:43 AM
master tech
There is a fix for the intrepid, All I need is the codes stored in the TCM. If you still have the car.
Old Aug 13, 2011 | 01:57 PM
lovvorn's Avatar
lovvorn
Default Computor Program
Hi , Take a 10mm deep well socket an remove your "battery ground cable " for 3 minutes an reinstall . The trans should shift better than new . The computer will have reprogramed itself . Your engine also resets itself too. You will have better performance & fuel milage . My Thoughts . Bud
