No heat on pass 00 Gr. Voyager
Old Aug 26, 2011 | 04:33 PM
peterg79's Avatar
peterg79
Default No heat on pass 00 Gr. Voyager
I have no heat on passenger side , 2000 Grand Voyager.can anyone help!!
Old Aug 26, 2011 | 06:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Do you have heat coming from the driver side? First thing I would check is the cooling system.
Old Aug 27, 2011 | 12:03 AM
peterg79's Avatar
peterg79
Thanks for taking the time to help.
Yes we have driver side heat, all we have on the passenger is full cold air, AC is very cold , can't blend the air like you can on driver side.
I believe the problem may lie with the air blend door based on other threads I have read.
Old Aug 27, 2011 | 12:38 AM
master tech
I think you maybe correct on the blend door.
Old Aug 29, 2011 | 08:31 AM
peterg79's Avatar
peterg79
How does one go about changing the blend door, I have looked on this site but have not found instructions on how to do it.
Thanks for your help.
Old Aug 29, 2011 | 08:43 AM
Tizzy1's Avatar
Tizzy1
Personally, I'm leaning toward the control head. It was very common for the temp slider to go bad so when you slid it back and forth, the resistance wouldn't change. On a 2000, you'd have to check it with a scan tool.
Old Aug 29, 2011 | 12:23 PM
peterg79's Avatar
peterg79
Thanks . Is there a special scaner for the H/C?
Sorry, I only know enough to be dangerous!
Old Aug 29, 2011 | 07:35 PM
peterg79's Avatar
peterg79
I ran the Calibration test, failed ( 2 simultaneous flashing LED's).
Would someone like Advanced Auto have a code reader I could use, or do I need to go to a dealer?
Thanks again.
Old Aug 30, 2011 | 12:26 PM
Tizzy1's Avatar
Tizzy1
I guess I'm not sure. Doesn't hurt to stop by and ask if there is one close to you.
Old Sep 6, 2011 | 10:07 AM
peterg79's Avatar
peterg79
I got a control head and tried it , same results, I am noticing that when the test is running and the driver side changes temperature, the passenger side stays cold and never changes.
I think it may be the air blend door.
Anyone know how to change it out.
I had the dash out last year to replace the condenser for the A/c, so I checked the electrical connections and they are good.
Help !
