Output speed sensor
Old Aug 26, 2011 | 10:46 PM
jonesoboneso's Avatar
jonesoboneso
Default Output speed sensor
Hey Guys I am after some help,
I have a 1999 caravan and all of a sudden the speedo and odometer stopped working, the check engine light is on and i cant get above 50kph (its an automatic)
I guess this means it is in limp mode, i have done a diagnostics test on the instrument cluster and no error codes appear and all the dials seem to move properly.
I have been researching this for a while and i believe it is the out put speed sensor...
Any clue if this is a correct assumption or could it be something else, i have located the output speed sensor from looking under the hood, but if i wanted to change it could i do it by putting the van on some ramps?
I have heard it is an easy procedure,I am no mechanic but if it's not too technical I can probably do it. I know its a cheap part, I just dont want to get ripped off at a garage...
Thanks in advance
Chris
Old Aug 26, 2011 | 11:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If you remove the air filter box out of the way and you can get to it from the top.
Old Aug 27, 2011 | 12:09 PM
jonesoboneso
okay thanks. how would i check it with a multimeter... should i disconnect it and remove it to test it or leave it in the transmission and test it?
also do i need to disconnect the battery?
Old Aug 27, 2011 | 04:34 PM
master tech
If you are getting a output sensor code, try replacing it first and to clear the code. Disconnect the battery.
Old Aug 27, 2011 | 04:46 PM
Cloak's Avatar
Cloak
there is no way to actually test that sensor with a multimeter.....it receives a magnetic pulse and transmits a signal.
you can actually get to it better from in front of the driver side tire......I just replaced one on my wifes Town and Country.
There are 2 sensors side by side ,,,,,,the Output Sensor is the one on the OUTSIDE.
Old Aug 27, 2011 | 05:04 PM
master tech
Yes there is a way to test the sensor. Put your DVOM on DC volts and with both leads on the sensor, using a piece of of metal. Pass it by the tip of the sensor. you should get a reading, it may not much. If it stays at zero, then its no good.
Old Aug 27, 2011 | 10:11 PM
Cougar41's Avatar
Cougar41
I'll be damned. Why didn't I think of that. Great tip MT.
Old Aug 29, 2011 | 11:29 AM
Cloak's Avatar
Cloak
Wink
I tried that...I was also told that if the tip of the sensor is still "magnetic" that it would be good....
Turns out, both ways I tested it, it was good, but after I changed it, cleared the code and completed the Drive Cycle, all was well..........
Not doubting you MT by any means.....just my 2 cents bro...you know how cars and trucks can be
Old Aug 29, 2011 | 12:56 PM
master tech
You use a other piece of metal and pass it by the tip, don't let it touch the tip. This breaks the magnetic field.
