Emergency Fuel filter/gas tank help!!!
Old Sep 6, 2011 | 06:49 PM
  #31
georgef's Avatar
georgef
They call for a brass punch because it reduces the chance of sparks and possible ignition of gasoline vapors.
George
Old Sep 6, 2011 | 10:50 PM
  #32
Philly2.4L's Avatar
Philly2.4L
Well i dont have a brass punch,so what can i use instead??
Old Sep 6, 2011 | 10:54 PM
  #33
steak59's Avatar
steak59
a big flat head screw driver.
Old Sep 7, 2011 | 12:31 AM
  #34
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
NM, question already answered...
Old Sep 7, 2011 | 11:31 AM
  #35
Tizzy1's Avatar
Tizzy1
wooden dowel?
Old Nov 10, 2011 | 04:02 PM
  #36
Philly2.4L's Avatar
Philly2.4L
Ok im finally back!I just got the the pump&filter in.Now it just keeps cranking,then trys catching,but doesnt start.It just sems to keep cranking.Im running outta daylight,so any help will be appreciated! Thanks
Old Nov 10, 2011 | 05:39 PM
  #37
Philly2.4L's Avatar
Philly2.4L
Ok i got it started.It starts up right away,its idling fine but when in gear its running real rough.Now i drove it and it doesnt have to much power.It did smell a bit when i first,like rotten eggs.That smell seems to have gone away,but the power loss is still there.Any thoughts?????
Old Nov 10, 2011 | 05:53 PM
  #38
Philly2.4L's Avatar
Philly2.4L
Also my check engine light has been on for a while now,BUT its blinking intermittintly on and off???
Old Nov 10, 2011 | 08:02 PM
  #39
Philly2.4L's Avatar
Philly2.4L
Ok i checked the codes and it says p1684(battery disconected recently) and p030 (misfire on no.4 cylinder).What to do next?????
Old Nov 10, 2011 | 08:56 PM
  #40
Tizzy1's Avatar
Tizzy1
Switch the plug and wire with another cylinder and see it the misfire moves. Move them to different cylinders so you know if it's a plug or wire. The check engine light flashes when you are in danger of melting down your catalytic convertor. Must be missing pretty bad.
