Emergency Fuel filter/gas tank help!!!
Old Nov 10, 2011 | 09:21 PM
  #41
Philly2.4L's Avatar
Philly2.4L
The check engine light had been on for a while before it died It didnt run like this before it died.When it first died she said it just stlled out at a red light,then started right back up?Running it outta gas so many times?The fuel pump no working correctly?
Old Nov 11, 2011 | 11:44 AM
  #42
Philly2.4L's Avatar
Philly2.4L
Is there an easy way to get to the plugs??
Old Nov 11, 2011 | 11:08 PM
  #43
master tech's Avatar
master tech
Site Moderator & Tech
Have someone else to replace them, just kidding. They are a pain, but really not that bad.
Old Nov 12, 2011 | 11:13 AM
  #44
Philly2.4L's Avatar
Philly2.4L
Any tips??,besides getting someone else to do it? lol
Old Nov 13, 2011 | 05:07 PM
  #45
Philly2.4L's Avatar
Philly2.4L
I switched around the wires,and i still got the same codes.I also pulled the plugs and they're dry and look very very old,and kinda look like they have been carbon fouled or something.They just look really old.Anyway,i cleaned them and gapped them (they were WAYYY off)and tossed them back in.Its still doing the same thing.No power,chugging when in gear,and a blinking check enginge light.I guess new plugs are next.Anybody know what to do next???? Thanks again!!!!!
Old Nov 13, 2011 | 11:02 PM
  #46
master tech
I would have replaced the plugs if I had them out. Try a new set of plugs and with the plugs out,do a compression test.
Old Nov 14, 2011 | 08:33 AM
  #47
Philly2.4L's Avatar
Philly2.4L
I got them out to late yesterday to get new ones.Im picking up new ones today,then ill give an update.Would the bad plug cause such big problems??
Old Nov 16, 2011 | 10:32 AM
  #48
Philly2.4L's Avatar
Philly2.4L
***UPDATE** So, i just got the new plugs in,and theres no change.The engine lights still flashing,and im still getting an 0304 code.I switched the wires around,but it still giving the same code.The exhaust kinda smells like rotten eggs,im not sure though but,it just smells strange.What should i do next??
Old Nov 16, 2011 | 05:58 PM
  #49
Philly2.4L's Avatar
Philly2.4L
***BUMP*** anyone???
Old Nov 22, 2011 | 07:52 PM
  #50
Philly2.4L's Avatar
Philly2.4L
So i replaced the plugs,and now the check engine light is off,but it's still running like poo.It has a little more power,and isnt chugging as badly as it was.Do you think its safe to drive to a shop??
