Driver Information retrofit?
Old Nov 29, 2011 | 09:50 PM
wely195's Avatar
wely195
Originally Posted by stlrj
I finally got it installed and working. It took an order from Ebay for the console and a trip to the wrecker for the harness and plastic mounting plate to complete.
The harness installation did require some splicing for the rear dome lights and splicing the loose black/blue to the other black/blue wire for the ground.
I made a template out of newspaper for the larger console from my wife's caravan console and was very careful when cutting the hole on my GC resulting in a perfect factory fit.
Later I'll need to wire the outside temp sensor but am still trying to find out how to add two pins to the multi pin connector at the fuse box.
Cheers,
Joe
Hi Joe,
I am trying to the upgrade my 05 Caravan with the overhead console too, got the console and harness from u-pull yard out of 2001 Caravan direct fit. The compass working fine but the temp showing - 40 at all times.
when checked the connector find out some wires color coded different like the harness i got of the yard has black/blue as you mentioned and the original connector has black/white in the same slot. could you please help on how you did it.
thanks
Wely
Old Nov 29, 2011 | 10:17 PM
Tizzy1's Avatar
Tizzy1
did you install a temperature sensor?
2001 overhead console diagram
2005 overhead console wiring
Old Nov 29, 2011 | 10:19 PM
Tizzy1's Avatar
Tizzy1
the overhead reads the ambient temperature from the bus from the front control module.
Old Nov 30, 2011 | 08:01 PM
wely195's Avatar
wely195
My Caravan is the base (SE) from the wiring diagram i see the note under the overhead console saying except base.
do you think i still could wire it up.
I know i have a lot of questions as i dont want miss everything up and end up buying new FCM or PCM.
Thanks
Walid
Old Nov 30, 2011 | 11:11 PM
wely195's Avatar
wely195
temperature sensor already installed original from Dodge.
Old Dec 1, 2011 | 10:56 AM
Tizzy1's Avatar
Tizzy1
did you connect the bus wires at the overhead console?
Old Dec 1, 2011 | 11:00 AM
Tizzy1's Avatar
Tizzy1
2005
Old Dec 4, 2011 | 03:23 PM
stlrj's Avatar
stlrj
Originally Posted by wely195
Hi Joe,
thanks
Wely
Hi Wely,
Your harness is fine. You now need to install an ambient temp sensor with wires. When I removed the sensor from the donor I also followed the two wires back to the bottom of the IPM ( integrated power module ) located behind the battery. I removed the multi-pin connector where the two wires went and cut off the rest of the wires so I could take the connector home with the two sensor wires still attached. You need to do this so you can learn how to remove the terminals from the connector in order to install in your connector. It looks impossible but the center block of the connector where all the connectors are located can be pried out of the connector housing with a small screw driver to expose and remove the terminals. You will need to install these two connectors with a few inches of wire into the same slots on your connector so you can solder the wires to the two going to the sensor.
Good luck,
Joe
Old Dec 5, 2011 | 07:04 AM
wely195's Avatar
wely195
Hi Wely,
Good luck,
Joe
Hi Joe,
Thanks for your reply, I have the ATS pre-installed from dodge originally, when checked the wires i see it going to the IPM and seems fine, even check the voltage in the sensor connector and read 5V.
no I dont see any fuse for the ATS but blue empty connector under the IPM that not attached to anything and looks like its relay connector.
so I am not sure if there is fuse i have to connect to make the ATS works or what else should I do?
Thanks
Walid
Old Dec 5, 2011 | 11:53 AM
stlrj's Avatar
stlrj
Hi Joe,
Thanks
Walid
Walid, there is no fuse to connect but you only need add the two sensor wires to the multi-pin connector that plugs under your IPM. Those two wires eventually connect to the BCM which is all the information it needs to give you the right temperature on your display.
Cheers,
Joe
