Caravan won't start - battery good - won't even crank
Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
think its a 3.0 or 3.2 liter engine. jumped the battery and still nothing. even had the battery charged and tested good. it will not even crank. lights come on but it won't crank. Obviously it is not the starter - tested good - or a fuel issue and probably not spark either. It just seems like there is no power but the battery tests good and even jumped it.
What could this possibly be?
Should i put the code reader on it?
What color is your key? Is there a little red dot lit up in the cluster? Some of them had SKIM even back then. There may or may not be a code for SKIM in the PCM, just depends on what the fault is....if your van even does have the SKIM on it. Jack in the code reader and see what you find. It costs nothing and takes a couple minutes. It's always a good idea to hook it up anyway for ANY electrical problem and see if there's anything there to lead you in a direction. If not then go from there and check for power at your solenoid wire. After that, another quick check is swap your starter relay with a known good one. Easy stuff to do before you start digging and spending a lot of valuable time.
I changed my transmission in doing so I broke the hot bolt off in side. I hooked the battery up it kept sparking I bumped the wires it stoped. I tried to start it then started sparking and starter smoked. I changed starter charged battery first time all gears were showing in boxes now I got nothing no power any were. windows lights dash ignition?? what could it be I am hoping not the control module. checking fuses tonight.. please help
