96 Caravan connector
Old Nov 6, 2011 | 05:30 PM
jetski0602's Avatar
jetski0602
Default 96 Caravan connector
Ok guys, so I'm a car nut, working on my father-in-laws 96 caravan, I can't find where one connector goes to.
I believe it's a connector from the egr solenoid valve but need help.
96 Dodge Caravan, 3.3L V6
see pics below
Old Nov 6, 2011 | 08:08 PM
jetski0602's Avatar
jetski0602
if your not sure where it connects to, can someone snap a picture of thiers under the hood.. 96-99 caravan 3.3l
It's behind the throttle, under the washer arms and parts compartment
Old Nov 6, 2011 | 09:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
That looks like the TPS connector.
Old Nov 6, 2011 | 10:20 PM
jetski0602's Avatar
jetski0602
i believe the tps is connected.. there is a connector on the side of the throttle body, connected already.. I know there is a tps and another throttle connector.. any other ideas anyone
Old Nov 6, 2011 | 11:04 PM
master tech
There are connectors for the throttle body. one is TPS and the other is the AIS ( automatic idle speed) motor. The EGR already has a connector plugged into it. The only others are the speed control servo or the MAP sensor.
Old Nov 7, 2011 | 11:08 AM
jetski0602's Avatar
jetski0602
Mastertech..
thank you very much.. it was the tps connector, the connector was hidden where it wasn't visible..
thanks again
