3 rd new axel in 1 year
Old Nov 26, 2011 | 10:35 PM
wilcom's Avatar
wilcom
Default 3 rd new axel in 1 year
I'm having problems keeping a drivers side axel in my 1995 3.0 dodge caravan. I can feel it again and this will be the third axle in the last year. When I take off or am under load I can feel the vibration starting again.
The van has 170K on it and runs good other wise, had a tranny at 114K and I did the water pump/timing belt about a year ago at 155K when this started
The motor mounts are all new , is there something else i can look for that is causing this thing to eat axles?
Thanks
Joe
Old Nov 26, 2011 | 10:48 PM
wilcom's Avatar
wilcom
I have new hubs on the last change and the axles I'm using are new but probably Chinese at O'Riely's auto parts
Old Nov 27, 2011 | 04:53 PM
steak59's Avatar
steak59
Try OEM axle, or Reman OEM axle. Aftermarket axle sucks.
Old Mar 17, 2012 | 09:12 AM
wilcom's Avatar
wilcom
My issue was NOT the axle, just felt like it.
The tranny was leaking so bad I took it to the local tranny shop for seals. They discovered a bad bearing in my differential case. It was causing the axle to wobble and feel just like a bad axle under load. It was in pretty bad shape when I finally took it in and they had to replace the bearing and the differential case.
Drives like a dream now
Old Mar 17, 2012 | 11:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
Thank you for the update.
