Antifreeze leak from A/C evaporator drain
Old Nov 27, 2011 | 04:54 PM
Iwagner's Avatar
Iwagner
Default Antifreeze leak from A/C evaporator drain
Hi all,
I'm looking for some help trying to pin down a coolant leak that I have in my 98 grand caravan. For about a 2 months I have had antifreeze leaking from the drain from the firewall on the passenger side of the van. I just stuck a pan under the van and put it on the back burner. About every week I would have to add coolant to the overflow reservoir. After much searching on this forum, I've read several posts stating that this could be a failing heater core. I just replaced the heater core and thermostat (it was bad), flushed the entire system and refilled with fresh coolant - and it's still leaking!! I can't figure this one out. I have no fluid leaking inside the van, no smells. I thought that the heating system was a closed system and didn't run through any of the A/C components, am I wrong about this? Could it be the condenser or the evaporator, and why would those have antifreeze in them?? Much thanks in advance.
Ian
Old Nov 27, 2011 | 07:05 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Try clamping off the heater lines going into the heater core. Does the system still leaks. No then you may have a bad heater core, even it is new. A new heater core can also be bad.
Old Jan 4, 2012 | 01:19 AM
Iwagner's Avatar
Iwagner
Just wanted to give an update. The leaking was just some residual fluid left in the A/C drain hose. No leaks and great heat, but the transmission just started slipping today...lol. Time for another job
Old Jan 4, 2012 | 08:11 AM
TurboStixx's Avatar
TurboStixx
lol Iwagner, it is a never ending job
Before you go all hay day on that tranny, I would check the TV cable and make adjustments if needed. (Pretty sure you Caravans have TV cables still (haven't looked under the hood of one in a little bit of time)
