wipers,radio,heater cutting in/out?
Old Dec 28, 2011 | 07:03 PM
aaronvan's Avatar
aaronvan
Default wipers,radio,heater cutting in/out?
Hello people,I am in need of some advise ASAP if you would be so kind.
I have a 2002 caravan se 3.3l.Starting on christmas day my radio,heater,and front wipers started intermittently cutting out.I have checked the fuse/relay box located under the hood and everything seems tight.is there another fuse box to check?It is doing it constantly now.The display on the radio flashes off and on as well as the blower motor for my heater as well as my wipers.
thanks folks
Old Dec 28, 2011 | 07:05 PM
steak59's Avatar
steak59
Did you pull the Fuse box out and inspect Under the fuse box for corossion? also pull the FCM in front of the Fuse box out, and inspect for corossion.
Old Dec 28, 2011 | 07:10 PM
aaronvan's Avatar
aaronvan
thanks for such a quick reply!...your talking about the box next to the battery under the hood?No I havnt,although I notice alot of orange colored dust in the box.Is there another fuse box inside the van?I cant find one if there is.
Just wondering,if corrosion was causing the problem wouldnt everything that box contains be having problems?
thanks again
Old Dec 28, 2011 | 07:15 PM
issakar's Avatar
issakar
thanks again
Orange dust usually = bad depending on what it is. Not everything would be affected if only one part was corroded. So for example it took one apart one time (not a caravan, different vehicle) and found corrosion on only a few parts.
Old Dec 28, 2011 | 07:22 PM
aaronvan's Avatar
aaronvan
Thanks!..I assume the orange dust being bad is because it's probably rust?I will yank the box out tomorrow and clen 'er up the best I can.
Do you know if there is a fuse box inside the van?I cant get a answer on that one.I certainly cant find one if there is.I was thinking loose fuse.
thanks again
Old Dec 28, 2011 | 07:31 PM
issakar's Avatar
issakar
I'm new to the Caravan but the intertubez says this:
http://answers.yahoo.com/question/in...9183826AAByosV
"when you open the drivers door look on the end of the dash panel there's a small panel there that you remove and all the fuses will be located in that spot,their easy to get to also,better than the old design of being under the dash,good luck with it,the owners manual will tell you what size and the exact location in the panel,good luck."
Hope that helps
Old Dec 29, 2011 | 03:31 AM
Cougar41's Avatar
Cougar41
4th generation vans (2001 - 2007) have a single fuse box under the hood near the battery. It's called the Integrated Power Module, better known as the IPM. It's the only fuse box on the van. The IPM is a known corrosion magnet. Disconnect the battery before disconnecting the IPM.
Old Dec 29, 2011 | 09:55 AM
aaronvan's Avatar
aaronvan
Thanks for the info!I am about to tackle it.Anything I should watch for or hidden problem areas?
thanks again folks..I will post back with results.
Old Dec 29, 2011 | 03:13 PM
aaronvan's Avatar
aaronvan
Well despite taking my time and freezing my hands,the problem is not resolved.I took out the battery and flipped the box open.One at a time i disconnected the plugs and individually cleaned each pin.Afterwards on the test drive the problem seemed resolved.A hour later as i went to drive home it acted up again..ARG.
Any other ideas?
thanks folks.
Old Dec 29, 2011 | 10:15 PM
steak59's Avatar
steak59
While it is not working, wiggle, tug, and pull on wires below the Fuse Box, if it comes back alive for few second...
I got a feeling you are going to need a New PDC (fuse box). remember to save all fuses and relay from the old one. Maybe the Corossion has eaten your fuse box from the inside alrdy.
Try avoid Junk yard one, you'll end up with same problem.
