Bad ECU or TCM?
Old Feb 2, 2012 | 04:42 PM
New2Dodgee's Avatar
New2Dodgee
Default Bad ECU or TCM?
Just picked up a 99 Dodge Caravan with an even 200K on the clock. The vehicle ran fine until one day when the transmission started acting up. It seems as though it starts out in second gear no matter what gear you select and will not shift out. Also there is no speed reading.
I plugged in my scan tool to read the CEL this is what happened..
The software shows 2 ECUs one called #40 with 19 readable parameters and the other ECU #41 with 5
My software showed no reading for intake air,maf,speedo and intermittent readings on RPM,load, timing advance and a bunch of other values were not readable or intermittent
Here are the codes..
Reverse Incorrect Ratio
Reverse first gear Ratio
vehicle speed sensor a
TCS MIL request
Here is all the values at normal operating temp while idling..
Uploaded with ImageShack.us
Old Feb 4, 2012 | 12:40 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would try a new input and output sensors.
Old Feb 4, 2012 | 03:02 AM
mbrahmer's Avatar
mbrahmer
I agree with changing the input and output sensors, first. BTW a 99 does not have IAT.
Your tranny is in LIMP home mode. Pull the pan too and have a look at the fluid and filter while you're changing the sensors (change them both).
