Transmission problems
Old Feb 3, 2012 | 08:07 PM
sunvan33's Avatar
sunvan33
Default Transmission problems
Hi,
I was wondering if someone could help me out with a transmission problme on my 1992 dodge caravan 2.5 liter engine 3 speed It won't shift from firdt to second gear it is automatic transmission. Any help would be great!
Old Feb 3, 2012 | 08:08 PM
sunvan33's Avatar
sunvan33
Help with transmission problem
Old Feb 3, 2012 | 10:32 PM
bjr1a's Avatar
bjr1a
Check throttle linkage to transmission...If linkage is connected properly , the problem is internal.......possible causes include valve body, broken band or the governor malfunctioned....would be good to remove pan and look for debri...
Old Feb 4, 2012 | 12:33 AM
master tech's Avatar
master tech
Site Moderator & Tech
Try from a stop, Put the shift lever in low gear and move the lever up to 2nd and then to drive. Does the transmission upshifts? If it does, the governor valves are sticking.
