Videos
Old Feb 9, 2012 | 05:14 PM
HuffmanFamilyof4's Avatar
HuffmanFamilyof4
Wink Videos
Does anyone have a video of replacing the left side CV Axle. I have to have the one on my 2000 Dodge G.C. replaced, as this will be the 1st time I'm attempting to do this myself(is this a good idea?) because i would like to save a few bucks doing it myself. I did the front hub assembly myself with information I got from this great forum(way to go members) a video showing things would be better. thank-you in advance. HuffmanFamilyof4
Old Feb 10, 2012 | 12:16 PM
Tizzy1's Avatar
Tizzy1
I have no video but it is not that difficult to do. Remove the axle nut and washer, seperate the lower ball joint from the spindle. remove the outer joint from the front hub. Pop the axle out of the transmission and pull it out. And as usual, swear every now and then.
Old Feb 10, 2012 | 01:23 PM
Cougar41's Avatar
Cougar41
...and throw tools. Very therapeutic. Just scope out a safe area before you start.
Here's one for a passenger side axle on an 06. Probably close. http://www.youtube.com/watch?v=Y8RNnRZL7GU
This video is not for a Caravan but it's full of good general tips. He talks about a wishbone. I don't think that applies to a Caravan.http://www.youtube.com/watch?v=jydxpsh13WQ
Old Feb 10, 2012 | 04:55 PM
maxbaby's Avatar
maxbaby
I was watching the video on that 06... when he goes to separate the tie rod, he talks about "the bolt on the bottom and the bolt on the top"... can someone clarify for me, when you indeed remove that cotter pin and bolt, do you then have to use some type of puller or pickle fork to get it to separate? I found the video interesting because I'm going to have to replace the tie rod ends before long on my 07...
Old Feb 12, 2012 | 03:02 PM
maxbaby's Avatar
maxbaby
bump...
Old Feb 19, 2012 | 04:22 PM
Cougar41's Avatar
Cougar41
I'm going to say no but I've only changed an axle on a Caravan once some time ago. It came right out. Some may be stubborn and need coaxing with a hammer.
Old Feb 19, 2012 | 04:49 PM
blknblu's Avatar
blknblu
A pickle fork will work, but there are less destructive tools out there.
You can borrow the proper tool from a car store.
Ask for a tie rod puller.
I have this kit:
http://www.harborfreight.com/5-piece...set-66686.html
It has payed for itself many times over. Look for a HF 20% coupon if you decide to purchase it.
Old Feb 20, 2012 | 12:33 AM
master tech's Avatar
master tech
Site Moderator & Tech
Very nice video.
Maxbaby
The bolts he was talking about are the two strut bolts and nuts. There is one upper and one lower. The reason you need to remove them is so you can get the axle shaft out of the outer bearing assy.
Old Feb 29, 2012 | 04:42 PM
HuffmanFamilyof4
Default got-r-done!!
thank-you for all the help. Went pretty well had a few issues I just swore a lot and took a few breaks and I got it done. this forum is awesome
