interior lights flicker door ajar light and bing bing fix
Old Feb 25, 2012 | 08:20 PM
ron29's Avatar
ron29
Default interior lights flicker door ajar light and bing bing fix
ok this was my problem i have a 2000 grand caravan es 91,000 miles the interior lights were coming on and off when i started driving it was like a lighting storm going off.and the door ajar light was going on with the bing noise . i was loosing my mind very bad situation at night.any way.I was very nervous cause i just bought the van last week.here is what i did to fix it.open the sliding doors you will see a silver pad on the left hand side clean them and also clean the 2 brass tipped posts that touch the pad to complete the circuit then take a Philips screw driver and carefully loosen the pad to slip something slim behind it .i used a piece of Styrofoam from a dun-kin donuts cup.just enough to extend it to make shure the tips were making contact with the pad i have not had a single problem from them since.I really hope this helps you i looked everywhere for help on the net and couldn't get any advise thank you and happy caravan-in
Attached Thumbnails interior lights flicker door ajar light and bing bing fix-van-001.jpg
Old Feb 26, 2012 | 11:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The sliding door switches have always been a problem on the NS body as well as the other body styles. You can also replace them and they are self adjusting.
Old Feb 27, 2012 | 09:43 AM
ron29's Avatar
ron29
thank you i might have to replace them after tinkering with them they were fine for a while and yesterday the passenger slider lost connection again.and had to adjust it again .do you happen to know the name of the part
Old Jul 21, 2013 | 03:42 PM
martyfa's Avatar
martyfa
My 2000 GC is doing the same thing. Did you ever get the part number(s) or price?
