Power Window
Old May 20, 2012 | 02:18 PM
pappyken's Avatar
pappyken
Default Power Window
Motor for window is only 1 year old, yesterday it stopped working, I banged on the door panel, nothing, put the dome light on and pressed the button, the dome light didnt do anything, checked around the window seal for sticking, seems to be ok, checked the fuse, ok, now Im out of things to check, please help. Its a 2005 caravan 3.3 litre.
Old May 20, 2012 | 11:41 PM
Cougar41's Avatar
Cougar41
Check for 12vdc at the motor connector with the switch thrown. If it's there and the ground is good change it again.
Old May 22, 2012 | 10:04 AM
pappyken's Avatar
pappyken
I went out to check the motor, so before I took off the door panel I pressed the button and surprise, surprise the damned thing is working again. It'll probably quit working again next week, so Ill just keep checking thins, Thanks a lot for your help
Old May 22, 2012 | 04:42 PM
Cougar41's Avatar
Cougar41
I've got one that's been doing that for years. When it acts up I just hold the switch, slam the door and the window comes alive for a while.
Old Feb 17, 2013 | 08:44 AM
Dennis Mastrolia's Avatar
Dennis Mastrolia
Default Window not working.
What switch do you hold when slamming the door? The one on the passenger side where the issue is or the drivers door while someone slams the pass. door?
Old Feb 17, 2013 | 08:47 AM
Dennis Mastrolia
I just checked the van after not doing anything for a while and the window is working--slowly-but working.
Old Feb 17, 2013 | 06:48 PM
Cougar41's Avatar
Cougar41
You slam the door that has the window with the issue.
Old Feb 28, 2013 | 09:00 PM
akewldewd's Avatar
akewldewd
This sounds like bad brushes in the motor. It sounds like time to replace the motor.
