Heater and airconditioning doors not working correctly
Old May 21, 2012 | 08:37 AM
welder4's Avatar
welder4
Default Heater and airconditioning doors not working correctly
I am having trouble with the mixing doors on a 2001 Caravan 3.3 . I have trouble with the heater working at all times some times it does and sometimes it don't . I tried to calibrate the heater and air and the light kept on blinking. the two middle outlets are strange as I feel warm air coming from the driver side and cool air from the one on the passenger side . I know there are four servos that operate the doors . what code would that show . I have burped the system many times and I don't think it is blocked with air pockets . At times it cools real well and others just some and not really enough in 90 degree temps . Winter time I have the heater working sporadically it works good and the next time you start it it will not work . I have the duel zone and use the recirculate and on button to calibrate it . any ideas what I can do with this ??
Old May 21, 2012 | 10:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would say you have broken bleed doors, But I would give tizzy a pm and ask him.
