2011 caravan front brakes on 2 to 3 weeks back order
Subscribe
Jun 12, 2012 | 08:48 PM
Does anyone know what dodge is doing for this brake issue? Upgrade rotor or same thing getting installed?? The dealer told me it should be covered ? they want to have a inspection before they order the parts??? Should i just go get aftermarket brakes or let the dealer install the same ones ??
Reply 0
Jun 12, 2012 | 09:23 PM
Not sure about the details, but if they're willing to do the labor and parts for free, even if you only get a year out of them again it's worth it. Put aftermarket on once it stops being a warranty issue.
Reply 0
Jun 12, 2012 | 11:10 PM
they are $100 deductible pads and new Rotors for front, extended waranty is 3yr-36k miles.
Believe it or no, aftermarket pads are no better than the factory one. I believe this is a design problem. The brake pads are just too small for the size of the vehicle. Just look at them, the pads are smaller than the one used in Charger. yet the vehicle is a lot bigger.
Reply 0
Jun 13, 2012 | 10:22 AM
question has anyone upgrade front brakes ??
the Grand Cherokee, Durango and Journey has the same bolt pattern as the Caravan. so how hard would it be to switch over a bigger brake kit maybe SRT ones hmmm???
Reply 0
Jun 14, 2012 | 06:41 AM
Quote: the Grand Cherokee, Durango and Journey has the same bolt pattern as the Caravan. so how hard would it be to switch over a bigger brake kit maybe SRT ones hmmm???
Maybe, probably would just need to make sure the wheels would clear bigger calipers.
Reply 0
Jun 14, 2012 | 09:15 AM
I have a 2011 GC and know that the 08 - 10 had premature brake wear. I asked my sales guy and he said that it had been fixed but I should get my brake serviced every year just to make sure the brake aren't sticking.
Is there another brake issue that I should be aware of.
I also see that Steak59 said front brakes have a 3 year warantee, I was told it was only one year.
Thanks.
Reply 0
Jun 14, 2012 | 10:50 PM
I try to make this easy for everyone, You need to replace the brake parts thats on the extented warranty. You can not use aftermarket parts at all. Warranty on brakes are 12 months or 12k, But with the extented warranty from 12k to 24k your deductable will 50.00 dollars and from 24k to 36k it will be 100.00 dollars. But you need to have the campaign part numbers on the the vehicle. I hope this helps, and i will post the TSB too.
SUBJECT:
Vibration At The Front Of The Vehicle When Braking And/Or Front Brake Pad Lining Life
(Warranty Extension)
OVERVIEW:
This bulletin involves installing new brake linings and replacing both brake rotors as
required.
MODELS:
2009-2011 (RT) Caravan / Town & Country
NOTE: This bulletin applies to vehicles equipped with brake sales code BRE and/or
BRG built after January, 01, 2009 and before May, 02, 2011.
SYMPTOM/CONDITION:
Vibration at the front of the vehicle when braking.
DIAGNOSIS:
1. Road test the vehicle for 5 minutes and intermittently apply the brakes.
2. Were there any vibrations experienced when braking?
a. Yes>>> Proceed to the repair procedure.
b. No>>> Proceed to Step #3.
3. Remove both front tire and wheel assemblies. Refer to the service information outlined
in DealerCONNECT>TechCONNECT>Service Information tab>22 - Tires and
Wheels>Removal
4. Using a Brake Lining Thickness Gauge or Brake Pad/Shoe Gauge, measure brake
pad thickness.
5. Perform the repair procedure if the brake pad usable material measured at its thinnest
point measures 4mm (0.1575 inches) or less.
NUMBER: 05-007-11
GROUP: Brakes
DATE: October 11, 2011
PARTS REQUIRED:
Qty. Part No. Description
AR (1) CNXBX361AA Kit, Front Brake Pad
AR (1) CNM2X252AB Kit, Front Brake Rotor (Contains 2 Rotors)
REPAIR PROCEDURE:
1. Remove the front brake pads. Refer to the service information outlined in
DealerCONNECT>TechCONNECT>Service Information tab>05 - Brakes> 05 -
Brakes, Base, Brake>Hydraulic/Mechanical>PADS, Brake, Front>Removal.
2. Remove any clips retaining the brake rotor to the wheel mounting studs.
3. Slide the brake rotor off the hub and bearing.
4. Clean the hub face to remove any dirt or corrosion where the rotor mounts.
5. Perform Step #2 through Step #4 on the opposite side of the vehicle.
6. Install brake rotors p/n CNM2X252AB over the studs on the hub and bearing on both
sides of the vehicle.
NOTE: Rotor replacement is recommended when switching to this type brake pad.
Standard brake service procedures apply thereafter.
7. Install new pads p/n CNXBX361AA. Refer to the service information outlined in
Brakes, Base, Brake>Hydraulic/Mechanical>PADS, Brake, Front>Installation.
POLICY:
Reimbursable within the provisions of the warranty.
Vehicles included in this Service Bulletin applies to U.S. Market (sales code YAA), Canada
Market (sales code YAC) and Mexico Market (Sales Code YAD). See Warranty Bulletins;
U.S. D-11-52, Canada SAB-2011-29, Virgin Islands and Puerto Rico ID-11-06 for details
associated with the extended warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
05-70-22-96 Inspect Front Brake Pads Only (B) 0.2 Hrs.
05-70-22-97 Inspect & Install New Front Pads,
Replace Both Front Rotors (B)
0.6 Hrs.
FAILURE CODE:
ZZ Service Action
05-007-11 -2-
Reply 0
Jun 15, 2012 | 10:09 AM
Thanks MasterTech.
Just to be clear. Is this extended warantee something that you had to purchase or given free by Chrysler?
Also, I believe my van was manufactured in July 2011 so it would not be covered as it shouldn't have this issue? Where do I find the brake sales code BRE and/or
BRG?
Thanks again.
Reply 0
Jun 15, 2012 | 10:17 AM
No, it will be on the function 14 or VIP sheet when you go into the dealer.
Reply 0
Aug 13, 2012 | 08:45 AM
I went to the dealer the other day since my 2011 Grand Caravan is having issues with brakes as well. The punched the VIN number into the computer and since my van was built on the 24th of May it is not covered. I am having the same issues as others so they obviously have not corrected the problem with vans built after the cutoff date as they claim.
Reply 0
Subscribe
