2003 Grand Caravan coolant leak
Coolant leak in 2003 Grand Caravan 3.3 L Flex fuel V-6. I replaced the water pump 6 months ago and the leak appeared to be in the same spot so I pulled it and had the parts store warranty it out. Put in the new pump and still leaked. I also replaced the small heater hose that connects behind the water pump. Still leaking and it appears to be the aluminum housing that the water pump bolts into....Is this possible?
