Problems with 2001 dodge grand caravan
Old 10-14-2012, 01:20 PM
Beth Richardson's Avatar
Beth Richardson
Beth Richardson is offline
Default Problems with 2001 dodge grand caravan
Im having a problem with the transmission. It seems to be something electrical, when it messes up it wont shift out of 2nd gear and the speedometer jumps from 20 to 60. My van is equipped with autostick, which i dont use. When it starts messing up al 4 gears light up when i put it in autostick. If i shut the van off it resets the computer, but it goes right back to doing the sae thing once i try to drive it. What could be causing this problem. The transmission in the van is a new one also. Its a 2001 dodge grand caravan.
Old 10-15-2012, 10:57 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
Your transmission is going into limp in mode. You need the to have the TCM scan for active or stored codes.
Old 10-16-2012, 02:08 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Anytime there's simultaneous shifting problems with erratic speedometer indications, the output speed sensor circuit is suspect. That sensor is the signal source for the speedometer and plays a role in transmission shift scheduling. It can be caused by a bad sensor, TCM or circuit wiring. A code read may or may not confirm it.
Old 10-19-2012, 10:32 PM
Beth Richardson
Can you tell me where the sensor is located??
Old 10-20-2012, 03:08 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
It is mounted on the driver's side front of the transmission. Here's an article with a diagram and pictures that also tells you how to access and replace the sensor. http://newprotest.org/details.pl?1410
Old 10-20-2012, 11:30 PM
Beth Richardson
Thank you for all your help! I had the input speed sensor changed and the output speed sensor. Finally my problem is solved Hopefully this will help others that have the same problem i did.
Old 10-21-2012, 09:12 PM
Beth Richardson
Default Gas gauge problems!
My gas gauge quit working now The needle bounces from full to empty when its on empty my gas light is on, also my dte drops to zero on my top display. What could be the cause of this?
Old 10-21-2012, 11:47 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Usually it's the sender in the fuel tank. It's part of the fuel pump so you change the pump and you have a new sender.
Quick Reply: Problems with 2001 dodge grand caravan
