I have a 2000 caravan and i have no brake light on the left side and the blinker is flashing super fast,i replaced the bulbs and still same result,any suggestions as to what the problem is?
Welcome to DF
Have you try switching the right side lamp assy on the left side? Also have you check for power and ground at the connector?
It has power going to the bulb because the parking lights work but just no brake and the reverse lights work,i'm thinking maybe faulty bulb making the blinker go fast.
In most case's thats true. But you could have a bad printed circuit board or bulb socket in the tail lamp assy. Thats why i ask you try switch the assy or even the bulb socket. The Jeeps have this same problem as well as the 1500 ram trucks.
Ok will do,will post the outcome
Got the blinker working normally but still no brake light on the left side,changed assemblies and the same thing resulted i have a running light and blinker on the left just no brake light.
Fixed!!!!! was just a short in the wiring :-)
